How do I wire a manual switch so I can turn my second cooling fan on whenever I want.
Car: 85 TA
I already bought a toggle switch...and now all I need to know is where to run the wires to. I know I have to connect the ground wires, and the hot wires...but I need a good desctiption of how to do all this. Thanks
88 Iroc 305 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , TPIS 170* t-stat, Richmond 3.73 gears, March Power & Amp pullies
First time at track: 14.781 @95.13 mph , & 2.204 60'
Check the tech section here, there's an article on doing that.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
What I did to get both fans running at the same time was jump a wire from the power on the first fan to the power on the second fan. This made both of them turn on when only one would turn on before. Then I wanted to add a switch to turn them on when the car was off so I ran a wire from the same jump wire from before, and connected it to a switch inside the car. Any other Q's?
Erik '89 Formula 350 TPI
14.10 @ 98 on motor
12.83 @ 109 w/NOS
http://www.geocities.com/formulal98/
14.10 @ 98 on motor
12.83 @ 109 w/NOS
eightsixseven
08-14-2015 03:09 PM
