305 cam
Old May 26, 2003 | 08:04 PM
stupid4901's Avatar
305 cam
I have an 87 LG4 and want to put a new cam in. What are some good choices and what do i need to get to install it. Everything is stock but will be changed to a street\strip over 300 hp combo.
Old May 26, 2003 | 10:48 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The LT1 cams work well with 305s.
Old May 27, 2003 | 04:12 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
but only 87+, right?
unless you switch to a roller block...i think
Old May 27, 2003 | 04:48 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have LT1 bump stick. I like it ALOT!
Old May 28, 2003 | 12:53 AM
Engine: 305-4v
Right.
He has an 87 so it should be ready for the roller cam already.
Old Jun 10, 2003 | 08:37 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Did the milage drop much with this cam change?
Old Jun 11, 2003 | 05:54 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Honestly with all of my other mods (Like higher gears)and liking to take off fast
I could not give you an honest answer. My guess would be only minor loss in mpg, if driven nice and easy.
Old Jun 11, 2003 | 07:26 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
It works but there are probley better choices in my opinion. What mod's are you making besides the cam ?
The cam's made to build power with a flat torque curve. I'd be looking at a com cams with a carb'd car.......
- 355ci, WS6, 5speed -
* Ported & Polished Big Valve Cylinder Heads (Cast # 993)
* 2.02 & 1.6 Manley Pro-Flo Valves
* Harland Sharp 1.6 Ratio Roller Rockers
* Crane Valve Springs and Retainers
* G.M.P.P. Ram Jet Roller Cam
* Crane Roller Lifters
* Speed Pro/TRW 1.25 Dome Forged Pistons
* Windage Tray
* Lightweight Nodular 16lb Flywheel
* Induction - Ported and Gasket Matched
Plentum
Manifold
Runners
52mm Holley Throttle Body
Custom Built Adjustable Fuel Pressure Regulator
#19 GPH Injectors running at 50lbs
* Exhaust All New
Edlebrock Chrome T.E.S. Headers
High-Flow 3" Carsound Cat
Dynamax 3" Exhaust Tubing and Tail Pipes
Flowmaster American Thunder Muffler
Personal Choice of Chrome Tips
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
