Put 305 in '80 Z28?
Old May 27, 2003 | 08:44 AM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Put 305 in '80 Z28?
I will be building a 350 and a friend is interested in my 305 for his '80 Z28 four speed car. We have been told that the 305 is internally balaced, but his old 350 may be balanced with the flywheel. Can we do this swap? Thanks.
Old May 27, 2003 | 08:49 AM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Sorry, may be on wrong board. Moderator please move if necessary.
Old May 27, 2003 | 10:38 AM
motrbreath's Avatar
You should be able to get some answers in here.
http://www.nastyz28.com/
Old May 27, 2003 | 10:51 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Whoever told you that is right, but they got it backwards.
The 305 has a 1 pc rear main seal. Because of the design of the rear of the crank, they weren't able to put a counter weight (aka 'throw') on the back of the crank, so they relied on the flywheel/flexplate.
As long as you use the correct flywheel/flexplate it'll be fine. You don't really have a choice anyway. The bolt pattern on the 1 pc rear main seal cranks are smaller anyway.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
jklein337
Sep 19, 2018 06:23 PM
