What is the biggest valve size that GM made for older stlye SB?
I Have a set of heads that i have had redone I am considering a 350 build or maybe a 400 the heads I have 2.02 heads from a 350/400 small block according to mortec and I was wondering what kind of horse to expect out of these heads on a 350 bored 0.030 over?
thanks
thanks
Transmission: 4L80E/4L80E
2.02/1.60 are the biggest valves Chevy put in production SBC's. The HP really depends upon what else you do (cam, induction, exhaust, porting, CR, etc.). The 1970 LT-1 that came with those heads (angle plugs) and 11:1 CR, solid cam w/~300 degrees duration, 780 Holley on a single plane aluminum intake, was rated at 360-375 HP; was barely streetable, and drank 100 octane at the rate of about 10 mpg in a no-frills 4-spd Camaro Z-28. With today's technology, you can do better than that on all counts.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, World 305 heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Hey five7kid, I thought the LT-1 used the Z28 High Rise dual plane manifold?
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
George P. Lara
1994 Z28 LT1 T56
MRZ28HO, I thought about that after I hit the "Submit" button. I think you're right.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
