black canister removal
Car: 1987 Iroc-z
Engine: 5.7L 350
Transmission: 700 r4
What is the process of removing the black canister in the engine compartment, and what are the cons of this....?
thx in advance
thx in advance
Car: 2002 Formula Firebird
Transmission: 4l60e
No cons..it probably doesnt do its job anymore anyways.
The only downfall is the metal fuel line that will be exposed. It will vent fuel vapor into the engine bay. You can cut the line back near the tank and run a filter on it. Or leave it open. People say this is a hazard but mines like that...im to lazy to fix it right.
Car: 86 z28
Transmission: built 700R4
the canister is there to filter fuel vapors before entering the atmosphere. if you dont live in an emissions state removing the canister is no big deal. just plug the lines that are attached to engine vacuum and you will be fine.
I didnt notice any metal line going to mine(86 iroc),maybe I missed it.The filter can be replaced but Im sure no one does it.If you have to pass a underhood visual inspection most inspectors will notice this missing.you could just set it there for inspection though.
Transmission: 4L80E/4L80E
The canister also provides the vent to the gas tank. If you just plug the lines, the tank will either be under vacuum when drawing gas out, or under pressure when the gas heats up. Neither is a good situation.
If you leave the line from the tank open, you'll be putting gas vapors under the hood.
It's hardly a "no cons" thing to do.
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i took mine out, sinc it uses copper fitting on the tb i solderd it closed, use a torch and some solder, fill the sucker right up, as for the line from the tank i put a little vaccum cap over it, the gas smell was just to much with it off.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Originally posted by SLP IROC-Z
i as for the line from the tank i put a little vaccum cap over it, the gas smell was just to much with it off.
You are surely asking for a problem without the vent...the pressure has to go somewhere when the fuel returns to the tank via the return line..and that isnt even talking about HOT days , and fuel expansion. I removed my cannister, but left the vent open.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Just do what I did. I'm running some vacuum tubing from that vent line into the front part of the fender. All fumes go out through there.
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Since it doesn't seem to be much of an advance to remove it, why not just keep it there? THen you'll pass emission visuals, don't have to worry about (dangerous) fuel vapors in the engine bay, or not venting the tank at all.
As I see it, the best, and easiest, solution by far, would be just keeping it!
Engine: 406
Originally posted by 99Hawk120
Why not just plug the metal line and run a vented gas cap like they did in the old days???
I think its both. Although I dont know what amount of gas you'll be wasting, i'd bet not very much. What get's me concerned, is the fire hazard. And little bit of gas isn't so little when your motorcycle burn right up, which my friends did. Nothing left of the engine than the block, only screws left of the carb.
In my opinion the canister system is a fairly good solution, quite similar to the expansion tank of the radiator.
If I remember right, it had two hoses connecting to it, didn't it? Wouldn't one of them be a return line?
1992 Trans Am
May 10, 2023 07:19 PM
