1.6 rockers instead of new cam?
Old Sep 13, 2000 | 04:38 PM
Justy's Avatar
My cam is still in good shape, but I wish it had more lift. Specs: 194/204 @ .05 - .398/.442 lift. The engine is just a carbed 305 with stock heads. Instead of getting a monster cam I figured 1.6 rockers would do me some justice right? Would I have to replace stock valve springs? Opinions? Thanks dudes.
Old Sep 13, 2000 | 06:06 PM
Jester's Avatar
1.6's won't do much for you. Less than 10hp..for the cost thats pretty lousy. I'd go with a new cam....you could use something with more duration anyway, thats really small.
Old Sep 13, 2000 | 06:38 PM
Box of Rocks's Avatar
Justy
1.6 rockers will add about 16 horsepower. You may need to grind extra clearance in the pushrod holes (located in the heads). Check with a 305 guy to see - maybe okay if left alone.
Save your nickels and dimes until you can pop for a 350. Good luck.
Boys.......I'm baaaack.
BOR
Old Sep 13, 2000 | 09:10 PM
zz4mula's Avatar
Car: FORMULA 350
Engine: ZZ4
my opinion is to save your money for a bigger engine. but if you must have some speed now,,,forgo the1.6 rockers and go get some laughing gas. either way you will be facing the fact that you need a larger, stronger engine.
Old Sep 13, 2000 | 09:35 PM
Vader's Avatar
Justy,
Box is right. 16.6 HP, 17.4 lb/ft of torque maximum - and that's if evertything else has been tweaked and the big bottleneck is the valve train. If you had a 9.5:1 TPI with enlarged exhaust, plenum, underdrives, synthetics, hot ignition, higher fuel pressure, etc., the extra lift might be of greater benefit.
For a relatively stock, low-compression 305, Jester is probably closer.
See a few of the earlier threads on 305 versus 350 and you'll see why the cost of the rockers might be better spent on an engine stand. I installed 1.6:1 roller tips on my '86 TA and it made a minor difference. And, yes, you can keep the stock springs with that cam and 1.6:1s.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 13, 2000 | 09:39 PM
Jester's Avatar
just FYI...the dyno test I saw was on a stock L98 out of a vette. It got a 9hp gain.
Old Sep 14, 2000 | 06:32 AM
Roy's Avatar
Roy
10 HP isnt worth it for the price and effort? I guess that is a rather subjective opinion since you can buy a set of stamped steel 1.6 rockers for about $65, use new pushrods for another $25 and install them in about an hour. Sounds worth it to me if I was looking for an inexpensive mod to get me a little more torque and top end.
Roy
Old Sep 14, 2000 | 09:05 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
agreed, roller rockers are worth every penny when you get a new cam cuz there is a lot less friction. the bigger rockers really dont give very much more lit or duration. i know i was thinking of the same thing, throw a se tof rollers on. but it wouldnt be worth it. ur definatel better off saving you money for an exhaust or some sort of induction mod OR a CAM, which is biggest problem!
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: Edlebrock 1 5/8's Headers, 2 inch cowl hood with custon alumin cold air box, 3.42 posi disc rear, T56, and hopefully a new set of heads and a nice CAM!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
