Can a K&N filter screw over my car?
Old Sep 14, 2000 | 07:00 AM
bowtieguy01's Avatar
One day i was doing the "free mods" on my air inlet sys.. So I pulled everything off.
I my engine looked really cool w/out in sys on there. And everybody dream about having a nice cam sound and a aluminum lung sticking through the hood. So I started the motor. It ran like sh*t. I figured it was because there was no restriction, no map sensor or maf sensor. I've always wanted that hot rod look under the hood. And I found a K&N filter that is coned and hooks right up to the throttle body. So what do I do w/ all those sensors in my air inlet sys.. will my engine run like crap if their off. Or can i do something to actatully use them w/ the filter?
I seem to be asking these q&a's everyday,
I wonder if anybody has noticed
Thanks for any help!
Bowtieguy01
Old Sep 14, 2000 | 07:37 AM
Vader's Avatar
BTG,
First, what year/model are you working on? If the engine had a MAF and assocoated plumbing before your filter installation, you are going to have to replace the original hardware or convert to a speed-density system. Converting would involve replacement of the ECM, PROM, anr either modifying or replacing the engine wiring harness. There is probably a K&N filter element designed to work with your original filter housing, but it won't be the type that connects directly tp the TB.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 14, 2000 | 09:09 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Also, with that filter, your sucking in a whole bunch of freash hot radiator air! NO GOOD MAN! hot air we all know makes less hp than cold air. You would be better off, rather than converting to speed density, in getting a cold air box like slps, or making your own, which isnt to difficult!
Steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: Edlebrock 1 5/8's Headers, 2 inch cowl hood with custon alumin cold air box, 3.42 posi disc rear, T56, and hopefully a new set of heads and a nice CAM!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Sep 14, 2000 | 02:09 PM
I have a 86 tpi vette. Also, i work at evans pontiac. And the sevan series t/a we have has these awsome lou gouliti(G2) deep dish rims. Would that rim use the same bolt pattern? I've wanted the new 5 star vette rims, but then I found out they have a different bolt pattern now!
thanks
bowtieguy01
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
maroe624
Apr 16, 2017 08:29 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
