Bad lifter?
Old May 30, 2003 | 10:44 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Bad lifter?
If you have read my post about injectors you already know that I have a loud ticking that gets louder at higher RPMs and only in Drive. I thought it was an injector but now I am wondering if it could be a lifter or pushrod. I would think that a bent pushrod would make a lot more noise. Could it be a lifter?
Old May 31, 2003 | 07:44 AM
Vader's Avatar
If you think it's an injector, unplug it and run the RPMs up to the point where the noise normally occurs. If the noise is still present, it isn't the injector.
Got a stethoscope?
Old May 31, 2003 | 08:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The lifters do not care what gear the engine is in. If the noise changes on that basis, it isn't a lifter.
You have an exhaust leak.
Get a piece of heater hose, take one end and stick it in your ear (I just love telling people to do that!!!) and probe around with the other end to find the noise. Forget the "maybe it's this, maybe it's that thing that 1 car in 10,000,000 has ever had happen", and attack it with logic and reason instead.
tyeo098
Nov 30, 2015 06:27 PM
RyanJB
Sep 14, 2015 03:39 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
