Setting TPS High Worth It Or Not?
Old Sep 15, 2000 | 01:00 PM
88 IROC BOB's Avatar
Just wondered if setting the tps to a higher voltage than normal really makes any difference or not. I know some guys say raise it as high as you can without setting a code. I checked mine today and it was at 0.68 (which I thought was out of spec) but had never thrown a code but I lowered it back down to where it should be. Does anyone think you can go quicker by adjusting it?
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Sep 15, 2000 | 08:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The only thing I can see it doing would be to allow the ECM to see WOT sooner to get you into the enrichment mode.
Old Sep 16, 2000 | 09:06 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
adjusting the tps higher helps in most cases. at .68 your already fairly high. it also gives higher wot voltage which helps with more fuel. allows it to run with a lower block learn number.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
