Code 32
Old Sep 14, 2000 | 08:23 PM
John Boy's Avatar
Code 32
What all could cause this code besides the EGR valve itself? I want to know everything to check while the plenum is off. Thanks guys.
Old Sep 14, 2000 | 09:22 PM
Kevin G's Avatar
OI would check the plastic vacuum lines to make sure they arent melted or cracked.
Also make sure carbon hasnt caked up the intake port where the EGR resides.
Yeah, it would suck to miss something after taking the plenium off.
[This message has been edited by Kevin G (edited September 14, 2000).]
Old Sep 14, 2000 | 09:58 PM
Vader's Avatar
JB,
It would help a great deal to know what engine/year you are talking about. Most EGR systems use a solenoid to activate the EGR pilot vacuum signal. Some EGR valves have a diagnostic temperature sensor to determine if the valve has opened when commanded to do so by the ECM.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 14, 2000 | 10:05 PM
John Boy's Avatar
It's an '86 Iroc with TPI, I've got alot of good answers I was just looking of where to start. thanks
Old Sep 14, 2000 | 10:23 PM
Vader's Avatar
JB,
An '86 TPI definitely has an EGR Diagnostic Temperature Sensor:
That needs to be connected and operating to avoid a DTC 32.
P.S. - While the plenum is off, are you going to "repair" the ports?
Old Sep 14, 2000 | 10:33 PM
John Boy's Avatar
My plenum saw it's fair share of "repair" when I sent my injectors to Rich.
Okay connected I can check for, but operating? What is it supposed to be doing anyway? Thanks.
I don't suppose EGR could contribute to a hard start, when hot, could it?
Old Sep 14, 2000 | 10:38 PM
Vader's Avatar
JB,
"Operating" would mean that it signals the ECM of a temperature change when the EGR opens. The sensor should have the same resistance-at-temperature scale as the MAT and CTS sensors.
An EGR that was sticking open would cause starting problems at any temperature. Your hot restart problems may have more to do with the MAT than EGR.
Later,
Vader
"Make Me Bad"
Old Sep 14, 2000 | 10:53 PM
John Boy's Avatar
So, checking it for resistance determines the likely hood of it being at fault? And it's resistance should coincide with that MAT? (Please correct if I'm understanding you incorrectly)
About the MAT contributing to hard starting when hot, do you recommend relocation? Or possible failure?
Old Sep 15, 2000 | 08:32 PM
Vader's Avatar
JB,
The resistance of MOST GM temperature sensors should be as follows:
Your EGR temperature sensor should be close to the table at a given temperature.
Later,
Vader
"Make Me Bad"
Old Sep 16, 2000 | 05:19 PM
John Boy's Avatar
Thanks Vader this is gonna help alot.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
