Which govener?
Old Jun 2, 2003 | 12:03 AM
rumpilstiltskin's Avatar
Which govener?
My new tci tranny in my 86 Z shifts way too early. Ive heard someone say your govener has to match your rear-end gears. I have also heard from others that i should just go get a corvette govener. I have 2.73 gears and will prolly have 3.42 gears in the future, (maybe 1 year). I dont have my old tranny to take the govener out of. What should i do? thanks
Old Jun 2, 2003 | 12:26 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If its a 700r4 the TV cable is probably misadjusted. I bet thats what your problem is.
Old Jun 2, 2003 | 01:47 PM
The tv cable is properly adjusted but that doesnt control the shift points in the first place. Any other ideas?
Old Jun 2, 2003 | 07:07 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The TV cable can affect the shift points. But it will only get you so far. If you are at the point where adjusting the TV cable has no effect on the shifts then it is your governer. Has the governer been replaced recently? Did the car just start shifting early?
Old Jun 3, 2003 | 06:42 PM
Its a brand new tci tranny. This happened on the first tci tranny they sent me. Now it has happened on the 2nd tranny they have sent me. Out of the box it has shifted like this. So should i just go ahead and get the vette converter or....?
Old Jun 3, 2003 | 08:27 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
b/m makes a governor recalibration kit. the governor can be accessed from the drivers side. there is a round cup you pop open and just pull the governor out. a little fluid will come out. there are springs connected to the weights. you will need to put stronger springs in. had to play with mine to get it to shift where i wanted.
http://store.summitracing.com/partde...rt=BMM%2D20248
Old Jun 3, 2003 | 10:07 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The Pro-built tranny that I just put in was shifting too early so maybe TCI is putting a different governer in there than what you need. Dana sent me a new governer that changed my shift points from 4200 to 5500.
Thanks Dana, It's working great.
Old Jun 4, 2003 | 12:21 AM
JesasaurusRex's Avatar
aww the simplicity of a T-5:hail:
Old Jun 4, 2003 | 06:57 PM
mrr23's Avatar
Engine: 360 HSR
simple, yes. strong, no.
Azrael91966669
Jun 22, 2010 04:06 AM
Crazy 84 Z28
Jul 8, 2007 04:51 PM
Luther6704
Jun 23, 2006 05:35 AM
Skatepunk60
Sep 9, 2003 12:55 PM
84blackbeast
Dec 5, 2001 07:26 PM
