When does the govener kick in?
Old Aug 21, 2003 | 09:23 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
My 85 2.8 can just keeps pulling on the highway .. ive never hit a revlimiter or govener , do i have one? She pulls slow but keeps pulling and the 85 mph speedo makes me guess how fast but ive definately done about what definately felt like 120 then had to back off cause a big turn or something.
Old Aug 21, 2003 | 09:29 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
dont worry dude..my 87 iroc is the same way(350 tpi)..ive burried the needle like 4 times (240k/h or like 160m/h?) and no signs of slowing down..and that was in 4th...not sure if certain cars got them or not..maybe you should ask this question in the history..and see...
iroc2nv
Old Aug 22, 2003 | 02:09 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
you should have a rev limiter, but its up around 6500rpm, something you will rarely see while driving.
to see if its working right, drop it in neutral and mash down the gas, it should rev up REALLY fast and then the rev limiter should kick in and RPM's will drop back down.
Old Aug 30, 2003 | 11:40 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You know what sucks? When had my 700r4 I could bury my 110 mph speedo without hitting a governor. But now that I have a T5 and a new PROM for the manual, I get STONEWALLED by the speed governor at about 108 mph. Not cool.
Never could figure out why my auto didn't have a governor.
Old Aug 31, 2003 | 07:27 AM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
i know my 3.1's governor kicks in at 115, so you might have that. if you can't see how fast you're going after 85mph, its hard to tell how fast you're going around 110, so you mighta just not hit the governor yet. not sure if the 2.8's were diff. from the 3.1's though
Old Aug 31, 2003 | 11:14 AM
Slow2.8's Avatar
i have a 89 2.8... don't know if its a governer or if my car just cant' top this speed, but i've never seen past 105, maybe its because the roads aren't long enough..
Old Aug 31, 2003 | 02:52 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Dizoward here..
my 2.8, @ 121 5th gear just under 4K, no more pull, but no speed limiter.
FYI, rev limiter at 6300.
Old Aug 31, 2003 | 04:54 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Did you get a custom chip or a "new" stock one? With a custom chip, you should've gotten the gov just prgrammed out of it. As far as I know, it's actually on the chip, kinda like VATS.
Old Sep 9, 2003 | 12:55 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I had a 3.1L camaro before it got smashed up, I know I had that thing reving really high before, well over 6500 and never hit a governor. It had a tranny problem, and wouldn't shift up on its own untill a little after 7k somtimes it was even worse than that. If I didn't crash the thing i'm sure I would have blow it up by now.
To make it shift you had to get off the gas, it would shift, then get back on right away or it would downshift again. I don't remember exactly what I had to do to make it shift but somthing wiered like that, so the thing was always over reving.
junior419
Apr 7, 2025 11:35 AM
L0tuS
Oct 4, 2015 08:07 AM
Giocio
Oct 1, 2015 12:20 PM
mcbitchman
Sep 29, 2015 12:32 AM
tattmann
Sep 27, 2015 05:20 PM
