Does anyone make an H beam rod for pressed pins?
Old Jun 2, 2003 | 12:15 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
I'm looking everywhere, and i can't find an H beam rod that will work with a pressed pin. I see tons of I beam rods, summit makes a set, and so does Lunati, but i'm gonna be spraying a rather large shot of nitrous through this thing (200ish shot, so about 600fwhp), and i'm not wanting to skimp out on rods. I already have the TRW forged pistons sitting here.
Eric
Old Jun 2, 2003 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
H-beam = $$$$ high-perf
Pressed pin = stock
There's a mismatch in there somewhere.
I doubt you'll find Z-rated mud tires, heads with pressed studs and 1.55" spring pockets, etc.
What are you really trying to do?
Old Jun 2, 2003 | 06:34 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Like RB said,
Do you really need h-beam rods? Perhaps you are overbuilding you shortblock.
I believe a set of high quality I-beams in 4340 steel will be more than adequate. Those Lunati street race rods you mentioned are some serious pieces.
By going with I-beams, you can keep your TRW pistons. Otherwise if you're bent on H-beam, you'll have to ditch your pistons.
Old Jun 2, 2003 | 09:35 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
If the ibeam rods will be ok with 600 hp on nitrous then thats fine. i'm not bent on any rod over another, i'm just told that the H beams are the only way to go.
Eric
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
BBSDesigns
Aug 11, 2015 07:39 PM
