Passkey Trouble Help!
Old Jun 2, 2003 | 03:29 PM
paul5.0's Avatar
Car: trans am 1991
Good day,
Im new to this board, and I wish that I could have found this website long ago. My name i Paul, nad I have a 1992 firebird TA formula with a 305 TBI. The car runs great!
The other day it just would not start. It has plenty of spark and fuel. but the injectors are not energizing.Im getting a fauld code of 53 when I jumper the 12 pin connector. I lloked up the code and it said V.A.T.S problem.
I assume that the security system or "passkey system" is messed up.
I have downloaded instructions on how to bypass the system with a resistor.
Could that be the problem???
Should I check for something else???
What should I keep in mind when bypassing?
If any one can help me, please email me back.
Thank you
Old Aug 13, 2003 | 10:09 AM
RBelflower's Avatar
Try cleaning your key. I had this issue but my Camaro would not turn over. I cleaned the 'chip' in the kay and then waited, started just fine.
I looked this up in the manual and the manual says that is the chip gets dirty then it can cause this.
Hope it helps.
Rob
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
