No error codes...wtf
Old Jun 2, 2003 | 06:27 PM
kinda_low's Avatar
Car: 89 Mustang
Engine: 5.0
No error codes...wtf (fixed it!)
I went down and bought the TPS and installed and adjusted it to .54V. I cleared the ecm and hooked it back up. I drove it around the block a few times and it runs horribly! I got home and checked the codes but there are none! The engine won't rev above 2500 even in park. It makes a horrible bogging/gurgling sound when accelerating. What could this be?? Thanks guys!
Old Jun 2, 2003 | 07:29 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Are you getting over 4.0V on the TPS at WOT?
Was there any other work done on the car recently?
Old Jun 2, 2003 | 07:34 PM
kinda_low's Avatar
Car: 89 Mustang
Engine: 5.0
getting 4.21V WOT. I recently installed a manual fan switch and my sterio...thats about it. I appreciate the help
Old Jun 2, 2003 | 07:48 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Is there any smoke coming from the exhaust?
Do you smell gas?
Does your oil look OK?
Did the problem start *right* after the TPS swap or was that an attempt to fix it?
Or did it start after the fan switch install?
Old Jun 2, 2003 | 07:51 PM
kinda_low's Avatar
Car: 89 Mustang
Engine: 5.0
Yup, it smokes when it starts so i know it needs new guides. BUt it only smokes a little when running and being pushed.
Yea i smell gas and since i got it it has been running rich. Lately the smell of actual gas inside has increased.
Its leaking oil pretty bad. I kinda notice that every time i take it out the oil leaks worse
The TPS was an attempt to fix the problem. This preblem was noticable before the maunaul switch but after its only gotten worse.
This engine just needs to hold on for 2 more monthes. Thanks!
Old Jun 2, 2003 | 07:55 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Has the fuel filter ben replaced?
If you smell gas inside the car then you must have a decent fuel leak somewhere. Check along your fuel lines and FPR to make sure you are pouring fuel out somewhere.
Old Jun 2, 2003 | 08:25 PM
Boxeat2469's Avatar
Sounds like a ruptured diaphram in the regulator, allowing it to suck fuel through the vacuum line into the intake.
Old Jun 2, 2003 | 09:02 PM
kinda_low's Avatar
Car: 89 Mustang
Engine: 5.0
Yes, the fuel pump and filter were recently changed too. It was "professionaly" done at a shop. Maybe the diaphram was just used to having crappy fuel psi from the old pump and the new one ruptured it? How do I tell for sure if this is the problem and where is the FPR located and how much to replace? Thanks!
Old Jun 2, 2003 | 10:49 PM
Boxeat2469's Avatar
The FPR is located under the very back of the plenum right in front of the distributor. Hook up a fuel pressure gauge to the rail. While the car is running, disconnect the vacuum line going to the FPR. You should see the fuel pressure jump up about 7 psi or so. Also, you can just disconnect the vacuum line going to the FPR while its idling and see if any fuel dribbles (or squirts) out of the nipple on the FPR.
Old Jun 5, 2003 | 11:36 AM
kinda_low's Avatar
Car: 89 Mustang
Engine: 5.0
I finally got real frustrated and brought it to a shop. Turns out it was my cat being totally and completely clogged up. I took it home and gutted it. all i can say is WOW No more knocking, more power than when i bought it, and it sounds great! Well now at least i know that i have good fuel pressure and a good working tps Thanks
Old Jun 5, 2003 | 01:37 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
glad to hear that you solved your problem.
antman89iroc
36
Jan 31, 2016 08:42 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
