Service Engine Soon light Comes on
Old Sep 16, 2000 | 08:18 PM
rwendt's Avatar
Car: 1991 Camaro Z-28
Transmission: 5 Speed Manual
Every so often, while driving, my Service Engine Soon light comes on. My car is a 91 Z28, 305 TPI with 5 spd. When this happens the car runs, accelerates, etc. normally. Do I need to check the codes???
  • 1991 Z28
  • Ultra Metallic Blue
  • 305 TPI
  • 5 Spd Manual
  • 3:08 rear axle
members.fbody.com/rwendt/
Old Sep 16, 2000 | 08:24 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Yes, check the codes.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old Sep 16, 2000 | 09:13 PM
CG's Avatar
CG
find a code reader and see what it says, dont take it to a garage, u will get charged an arm and a leg
Old Sep 17, 2000 | 03:35 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
you dont even need a code reader. just get a short wire or paperclip and jump terminals a & b of your aldl connector. if you need to know more on this or you dont know what a aldl is, check this website under tech articles.
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astra...uild/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 17, 2000 | 12:40 PM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
That would happened to me only when i would drive get up to 40-55 mph after a morning start. I got a code 32 which is related to the EGR valve. I replaced the EGR valve and the code never appeared again. I got a little key to check the codes free from Autozone. If you have one near you just ask if you can have a key to check the engine codes(they should give you a key and instruction booklet). Hope this helps
Shouldn't bother putting this but hey what the heck:
1988 Maui Blue Firebird 305 TBI stock
[This message has been edited by Highwind (edited September 17, 2000).]
Old Sep 17, 2000 | 08:37 PM
Vader's Avatar
R,
If I were getting an indicator light warning of a problem, I would want to check it out. You can scan the ECM for codes with no more than a paper clip and information:
The paper clip is your responsibility, the data is here:
GM Error Codes.pdf.
You'll need Adobe Acrobat Reader to view the file. (See link below.)
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 17, 2000 | 10:37 PM
matthew's Avatar
My car does that too. It all depends on how long I let it warm up in the morning. If I let it warm up for a couple of minutes, it won't come on during my trip to school. (15 miles) but if I'm in a hurry and only let it warm up for like 30 sec. then it comes on.
Old Sep 17, 2000 | 10:50 PM
Bishop69's Avatar
The paper clip is idea is the best idea. Sometimes, if you floor it your knock sensor will come on briefly because of the all of the vibration.
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
