oil pan change
Old Sep 16, 2000 | 02:23 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
oil pan change
i'm looking into changing my oil pan . any of you guys do this with the motor in the car? is this possible ? i've got a400 in my car don't know if the crank makes adifference
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Old Sep 17, 2000 | 08:08 PM
Birmass's Avatar
Well I was able to do it in mine with a 350 and 700r4 so I would imagine that you should have no problems. All I did was take out the distributor so it didn't hit the firewall, undo the motor mount bolts, undo the exhaust, and jack it up as high as it can go. You should be able to just barely slide it out. Good luck, it's a pain in the you know what. Also, you won't have much fun with the gasket when you put it back on.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Sep 17, 2000 | 08:21 PM
Vader's Avatar
Craig,
It is possible. Just out of curiousity, why would you change the pan and nothing else?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 18, 2000 | 03:50 PM
craig's Avatar
Car: 86 camaro
the reason iwant to do it now is i have the money for the pan i want which i didn't when the motor was rebuilt.just upgrading as money permits
Old Sep 18, 2000 | 04:08 PM
Colin 86&87 IROC-Z
Guest
Posts: n/a
if you are changing the pan you should also put in a better oil pump... make sure your pan has a windage tray, if you are changing it might as well go the whole 9 yards
maroe624
Apr 16, 2017 08:29 AM
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
