stumbling/missing idle
Old Sep 14, 2000 | 10:04 PM
Tab92bird's Avatar
My car starts up fine, idles fine at first, but once the idle goes down to 550-600 the engine starts to stumble. I also noticed that when it does this sometimes it will cycle back into closed loop for half a second.
I've done all the major tune-up stuff and nothing has solved the problem (although cleaning the plugs helped it). Please help!
Thanks,
Brandon
White '92 Firebird w/ 305 TBI. Open element w/ non drop base, increased fuel pressure, TBI spacer, Hedman Hedders & y-pipe, no cat, cat-back exhaust
Old Sep 15, 2000 | 01:57 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
i hope you meant going back to open loop and not closed. how do you know it went back to open loop? things to check, Coolant temp sensor, map sensor, and maybe egr,even though you arent getting codes it still may be operating in its parameters but still effecting idle and acceration. if not check for intake mani leak or hose leaks. good luck
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astra...uild/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 15, 2000 | 01:56 PM
Tab92bird's Avatar
btt
Old Sep 15, 2000 | 05:59 PM
JP84ZROC
Guest
Posts: n/a
The MAP sensor is a good place to start. If you have a scanner check the voltage and see if it is stable or if the voltage jumps around quite a bit at idle, mine would fluctuate quite a bit and it turned out to be bad. It was not steady on the tenth's scale ie: it would keep changing from about 1.3 to 1.8 volts at idle. Also you can tap on the MAP sensor with a screwdriver and affect the idle quality if it is very bad, much like they do with the MAF to check it in worst case scenario.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 15, 2000 | 07:59 PM
Vader's Avatar
Originally posted by Tab92bird:
...I've done all the major tune-up stuff and nothing has solved the problem (although cleaning the plugs helped it). Please help!
Thanks,
Brandon
Brandon,
I hope that the "major tuneup stuff" included cleaning the IAC passages and valve pintle. You should also have cleaned or replaced the PCV valve, since it controls vacuum to some extent.
A leaking EGR solenoid vavle or leaking EGR valve can also cause poor idle quality. What is the intake vacuum like when this occurs?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 16, 2000 | 06:06 PM
Tab92bird's Avatar
Yes, I did clean the iac passage with carb cleaner. The pcv is working fine, but I sprayed it with carb cleaner just to be sure. The MAP voltage stays at 1.5 volts. I forgot to mention that there is a distinct popping noise coming from the exhaust when this happens. it's not loud like a backfire, and it's not noticable unless you are standing right behind the car.
Old Sep 17, 2000 | 10:13 AM
Tab92bird's Avatar
btt
Old Sep 18, 2000 | 05:03 PM
Tab92bird's Avatar
Can anyone else help me???
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
