swapping in 5 speed pedals..
Old Jun 5, 2003 | 02:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
im in the process of putting my 5 speed pedals in and im wondering what i should use to make the hole in the firewall.. im curious to hear how others have done it.. im debating on if i should just drill 2 large holes and file them to make the oval hole or if i should use a sawsall and try to see how neat i can be.. any suggestions?
Old Jun 7, 2003 | 10:21 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I drilled like 7 small holes then used the chuck to smooth it out. It was a big pain in the ***.
Old Jun 7, 2003 | 11:53 PM
ctandc's Avatar
Just did this awhile back......
Get a 1 1/2" holesaw attachment for your drill.
Take out the booster and the auto pedals.
The 5 speed pedals should have (2) braces bolts to them, once you have pedals mounted loosely, look under the carpet for this
Old Jun 7, 2003 | 11:56 PM
ctandc's Avatar
Rip the piece out in the middle like I did, this is where the master cylinder goes thru.
No see where the braces are with the pedals in? Drill the two holes using the holes in the braces as a guide. This is where the U-bolt goes that holds the clutch master cylinder in.
Now with that done, simply use the holesaw to cut the hole where the master cylinder will go.
Good enough?
You WILL NOT regret the swap
HTH
Old Jun 8, 2003 | 01:05 AM
89RsPower!'s Avatar
whats the piece to the right side of the hole in the picture? did i forget 2 take somethin from the junk yard????
Old Jun 8, 2003 | 07:17 AM
ctandc's Avatar
There are the (2) metal braces that are bolted to the 5 speed pedals. The black thing is a hose for the cruise control, it was just in the way during the picture.
HTH
Chris
Old Jun 8, 2003 | 10:40 AM
89RsPower!'s Avatar
oh phew had me worried for a sec
Old Jun 8, 2003 | 11:00 AM
89RsPower!'s Avatar
anybody have any pics of the assembly installed? i cant remember where the reservoir bolts 2..
Old Jun 8, 2003 | 11:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It goes to a little bracket that hangs off to the driver's side of the brake MC, it fastens under the nuts that hold the MC to the booster.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
