TPS Setting for SD
Old Sep 18, 2000 | 11:41 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
TPS Setting for SD
I have a 92 TA with 5.0tpi. I saw somewhere that the tps should be set at .70. Is this correct? I had to enlarge the bolt hole to get it that high.
92 1LE Trans Am
5.0 Liter, 5 speed
SLP Headers
Dynomax Cat-back
SLP Cold Air, Chip
SFC, Strut Tower Brace
Old Sep 18, 2000 | 01:04 PM
rondubbs's Avatar
thats way too high you will set off a ses code.. .62vdc is the highest , i believe
Old Sep 18, 2000 | 02:34 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
IIRC the SD computers zero out the TPS reading. I've read conflicting posts as to what year this really started, but they all agree the SD cars had the zeroing out feature, I think they came with the non-adjusting TPS sensors (no slots).
Old Sep 18, 2000 | 02:55 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
MrJ wrote this at Thirdgen.
The .54V ideal setting is for the MAF cars. The ideal SD TPI setting is approx. .70V, as the SD TPI TPS is different than the MAF version. It's non-adjustable from the factory, but the screw holes can be enlarged to allow adjustment. Just throwing this out there...
Where did these numbers come from? The car seems to run the same. But I'd like to have the tps set correctly.
I'm going to reply to this over also, just in case MrJ isn't here.
Old Sep 18, 2000 | 03:16 PM
MrJ's Avatar
MrJ
I AM here... and it's true. The stock value is .71, I believe. Don't listen to the MAF guys.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
Old Sep 18, 2000 | 07:01 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My stock setting is 0.64v
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 18, 2000 | 07:37 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
All speed density computers, 1990 thru 1992, can set the TPS any where between 0.4v to 0.9v as stated in service manual. The larger the voltage, the longer the injectors pulse on for a richer mixture.
Old Sep 19, 2000 | 10:01 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Could a richer mixture cause a higher idle speed or a slight hesitation? I'm at .70v rightr now. I'll try lowering as far as possible tonight.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
