TB bypass question.... HELP!
Old Sep 19, 2000 | 12:22 PM
350Iroc's Avatar
I did the TB bypass this summer when I installed my miniram....what I did was just plug it off. After the install I had no heater...is the TB bypass part of the heater system?? Thanks!!
350Iroc aka 350Z
Old Sep 19, 2000 | 12:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
What did you plug off? Only thing to plug off is the holes on the TB Should have hose from heater valve to the Manifold. Hope you put the hose on the right outlet on the valve.
PS not part of the heating system.
[This message has been edited by Mkos1980 (edited September 19, 2000).]
Old Sep 19, 2000 | 12:30 PM
Vader's Avatar
350,
You need to maintain flow through those hoses, even if the flow does not route through the TB base. The hot water from the back of the head needs to recirculate to the water pump to scavenge air and steam from the end os the head. You should have installed a splice in the two hose ends to complete the job.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
$750 L98
Feb 1, 2025 02:25 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
