cam,with these heads
Old Sep 17, 2000 | 09:37 PM
SCOTTCAMARO1's Avatar
ok im going to be running dart iron eagles with the 2.02/1.60 64cc 215 intake runners around 9.8:1 compression.in a 383, 700r4 tranny and 3.42:1 rear what cam would everyone suggest????? reminder this is a dailey driver:confised:
Old Sep 18, 2000 | 04:13 PM
Polecat's Avatar
I chose the Lunati Bracket master cam. Its 292 adv., 230 @.050 and .480 lift. Perfect for a torquey daily driver, and still has that lopey idle you'll love. Responds well.............
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Sep 19, 2000 | 07:08 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
You don't indicate what intake (or converter stall) you are running but you should consider the Comp Extreme rollers. like
(in order of most radical to mildest) http://www.compcams.com/speccard/08-433-8.txt
PART # 08-433-8
GRIND NUMBER: CS XR288HR-10
ENGINE: CHEVY SM BLK 305-350
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .520 .540
.006 TAPPET LIFT 288 294
VALVE TIMING OPEN CLOSE
AT .006 INT 38 BTDC 70 ABDC
EXH 81 BBDC 33 ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 106 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 236 242
LOBE LIFT .3470 .3600
LOBE SEPARATION 110
THIS CAM SHOULD USE SPRING # 986-16
or
http://www.compcams.com/speccard/08-432-8.txt
PART # 08-432-8
GRIND NUMBER: CS XR282HR-10
INTAKE EXHAUST
GROSS VALVE LIFT .510 .520
.006 TAPPET LIFT 282 288
AT .006 INT 35 BTDC 67 ABDC
EXH 78 BBDC 30 ATDC
INTAKE EXHAUST
DURATION AT .050 230 236
LOBE LIFT .3400 .3470
LOBE SEPARATION 110
or
http://www.compcams.com/speccard/08-423-8.txt
COMPETITION CAMS CAMSHAFT SPECIFICATION SHEET
PART # 08-423-8
GRIND NUMBER: CS XR276HR-10
INTAKE EXHAUST
GROSS VALVE LIFT .502 .510
.006 TAPPET LIFT 276 282
AT .006 INT 32 BTDC 64 ABDC
EXH 75 BBDC 27 ATDC
INTAKE EXHAUST
DURATION AT .050 224 230
LOBE LIFT .3350 .3400
LOBE SEPARATION 110
The Dart heads have good flow in the .5 range. You might consider the milder cam with 1.6 rockers. Ultradyne (<A HREF="http://www.ultradyne.com/hydraulic_rollers.htm" TARGET=_blank> http://www.ultradyne.com/hydraulic_rollers.htm),</A> camotion and Crower also have some real nice hyd roller designs.
[This message has been edited by jcb999 (edited September 19, 2000).]
Old Sep 19, 2000 | 11:43 AM
i dont want to go with more than a 2000 stall converter and im going to go with the stealth intake with a tbi adapter
Old Sep 19, 2000 | 12:23 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
in that case you should try to find a cam that has about 214 to 220 degrees intake duration at 050 and at least a 112 lobe separation angle. And considering these cams will not have a whole lot of lift, you might consider 1.6's.
This will be a pretty stout cam for a TBI combination. I am not sure what will be involved with obtaining a correctly programmed chip but it will certainly need one.
Old Sep 19, 2000 | 06:05 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Try the Comp 268 extreme energy cam. The Goodwrench motor achieved 408 hp with vortec heads and 1.6 roller rockers. A 2000 stall would probably work with this cam.
gta90
Sep 15, 2015 04:00 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
