Engine still missing
Old Jun 6, 2003 | 03:02 PM
notaustin83z's Avatar
Car: 87 Trans Am
Engine: 350 Super Ram
Transmission: Level 3 Raptor 700R4
hi
alright...i checked the fuel pressure (42psi engine off/37psi at idle) and i changed the plugs again (AC Rapid fire gapped at 35)..The engine still misses. It got a little worse now too, it misses all the time, through the whole rpm range. I unplugged the maf to put it in limp home mode, and the sputter persisted. I also tried unplugging the O2 to do the same, but the SES light never came on (could this mean my ECM is bad?). Like I said in my first post, I have replaced the cap and rotor, new wires and plugs, timing reset to 6before, new coil, new fuel filter, tested the fuel injecters (16.7 ohms each), and tested the fuel pressure (came out ok).
thanks for any help, nick
Old Jun 7, 2003 | 11:56 PM
Vader's Avatar
I went through a similar bout a few years back. I finally removed my injectors, had them cleaned and flow matched, and haven't had a problem since.
Old Jun 8, 2003 | 09:01 AM
ede's Avatar
ede
injectors would be a good guess, might want to try compression test and check the cat too.
Old Jun 8, 2003 | 12:58 PM
Car: 87 Trans Am
thanks for the replies...im a little low on cash for now so I can't get the injectors serviced right away, but that will be my next step. I have a compression guage so I'll go see how that is doing while the weather is still nice...
yeah...my catalytic converter sort of "disapeared" a while ago...so it can't be clogged...
thanks, nick
Old Jun 8, 2003 | 03:34 PM
Car: 87 Trans Am
Vader, how much did having the injectors serviced set you back?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
