What are some tricks to get rid of a part throttle low RPM bog?
Old Sep 19, 2000 | 09:51 PM
Mike92's Avatar
My TBI keeps bogging at part throttle but usually won't at near WOT. Also my car accelerates harder at 3/4 throttle than full WOT. Could it be detonating at WOT and this be why it isn't quite as fast. Thanks for any replys.
Old Sep 19, 2000 | 10:02 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Well, I had similar problems w/ my 86 IROC's 305 TPI and it turned out to be the TPS out of adjustment. Had a bog, ran out of breath at WOT (guess it was going lean?, beats me), and the disengagement of the TC under light throttle was also a little rough. Adjusted it and the problems went away, actually made a rather large difference for something so simple. I am assuming a TBI car also has a TPS, if not ignore me.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited September 19, 2000).]
Old Sep 19, 2000 | 10:06 PM
Mike92's Avatar
It does and I thought I put it in spec. It should be at .45 volts at idle and over 4volts at WOT right? I think I may adjust it up a little. Right now it gets almost 5volts at WOT and it a little under .45 volts at idle. I think. Does anyone know the exact specs and/or reccommend a setting I should try in my setup? Thanks Ray
305TBI FireBird, Holley Intake and TBI, Headers, Torquer Heads, Gears. Best E.T. 15.08 at 92.5, 0-60 6.45.(Before Heads)Summit cam purchased 204-214, to be installed in 350 shortblock "soon" Shooting for 13's, oh yeah!
Old Sep 19, 2000 | 10:28 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
For a TPI car it should be around .55 volts closed throttle and over 4 at WOT. Sounds like your base setting is a little low. Hopefully that is the prob. Again I'm assuming the TBI setting is the same on the TPS as it is for TPI.
There is a article in the Tech Article Section here that lists instructions on setting the TPS, (lists base specs as .54 + or - .075). I double checked it but it doesn't specify if its standard between TPI and TBI or not. Perhaps a TBI guru will pop up w/ the goods here...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
