shaft stuck in the distributer
Old Jun 7, 2003 | 11:38 AM
notaustin83z's Avatar
Car: 87 Trans Am
Engine: 350 Super Ram
Transmission: Level 3 Raptor 700R4
I yanked my distributer today to put a new pickup coil in it. everything went fine until i tried to slide the shaft out. It slides up about 6" then gets stuck. so far I just removed the ign. module and took the gear off of the bottom of the shaft. Am I missing a step? or is my shaft/housing damaged?
thanks, Nick
Old Jun 7, 2003 | 12:30 PM
Odyssey's Avatar
When it's old, it'll do that. Just yank on it until it comes up!
Old Jun 7, 2003 | 02:18 PM
Car: 87 Trans Am
yep...took about a half hour of me and a big friend tugging on each end. popped in my new pickup coil and module, started her up, and heard the wonderful sound of my engine misfiring. I don't think im ever gonna get this thing fixed...ran out of things to replace...
thanks, nick
Old Jun 8, 2003 | 12:00 PM
Damon's Avatar
Yeah, ancient oil spooge build up on the shaft and prevents it's easy removal.
Old Jun 10, 2003 | 01:49 AM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
dude you put it back in exactly the same way? had same problem, we were one tooth off, fixed that and it fired right up
Old Jun 11, 2003 | 10:56 AM
Car: 87 Trans Am
yup i lined up all the marks i made, and checked the timing afterwards (6 degrees base timing). I replaced everything in the distributer (along with a ton of **** outside the distributer) to fix the misfiring, but it didn't work. Im taking out the injectors today to have them cleaned...hopefully that will solve my problem...
Gunner242
Dec 25, 2015 04:49 PM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
6998poncho
Sep 25, 2015 02:56 PM
