Dropped a bolt into the tranny....
I realize this is probobly not the right area to post this, but, I figure everyone in here would know just as well.
Today when I was replaceing my TV cable, I just happened to drop the bolt that holds the cable housing onto the transmission, into the hole where the TV Cable ENTERS the transmission.
Now, my question is, is it possible to remove the bolt by dropping the pan.... or is this more serious than that.
And yes, I've tried a magnet and what not, no little tricks seem to be working for me, gonna try one of those claws that are enclosed in a big spring looking thing 2morrow, but, if I can get it by dropping the pan, I might as well.
Adam
Adam
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You've got to drop the pan to install the TV cable anyway.
Originally posted by Vader
And while you're at it. you might as well install a drain plug in the pan if you don't already have one.
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
