roller rocker dilema
Old Jun 10, 2003 | 04:02 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
i have found out that my 1.5 ratio 3/8" stud roller rockers are summit aluminum part number SUM-G6910B. nowhere on the summit site does it say anything about centerbolt valve cover compatibility. Are these rockers OK to use with centerbolt valve covers, if not i think i know why my car is having so many problems.
thanks
Old Jun 10, 2003 | 04:45 PM
highpower's Avatar
I don't know if they are off hand. I would give Summit a call and ask. And remeber it's our duty to ensure all ford owners are well aquained with the rear end of your car. :rockon:
Old Jun 10, 2003 | 05:38 PM
Car: 1988 GTA
Engine: 355
hahaha im in mass too what town you live in, i live in easton.
Old Jun 10, 2003 | 05:46 PM
highpower's Avatar
Hey! a fellow M*******! LOL! I'm in Longmedow (outside Springfield). Have you checked out the regional messege board? Guess someone is starting/started a 3gen car club. Know anything about it?:rockon:
Old Jun 11, 2003 | 09:26 AM
Car: 1988 GTA
Engine: 355
I called summit and the guy said "No, sir." haha, guess ill be shopping for some rockers.
Old Jun 11, 2003 | 09:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK the only self-aligning ones with a narrow enough body for the centerbolt boss thing to fit between them are the Crane aluminum ones, which you can also get from GM. Personally I will not put aluminum roller rockers on a motor I intend to drive on the street, but that's just me; I like to drive my car and leave the hood closed alot.
But that may or may not have anything to do with "problems" your car is having. What are these "problems"?
Old Jun 11, 2003 | 12:23 PM
Vader's Avatar
RB,
Have you experienced clearance problems with the Comp 131Xs?
Old Jun 11, 2003 | 12:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've never tried to install those in a center-bolt situation, so I couldn't say. They do appear to be somewhat wider at the trunnion than the inferior aluminum Crane product though. Others report that they had to "modify" their valve covers a bit to use the Comps.
Old Jun 11, 2003 | 12:39 PM
Vader's Avatar
"Modify"...
That's such a broad term. Installing chrome lug nuts wou be to "modify". Michael Jackson has also been "modified"...
It's just a matter of degree, I guess.
I did notice the wide trunion on the Comp steel rollers and wondered.
Thanks.
Old Jun 11, 2003 | 02:13 PM
Car: 1988 GTA
Engine: 355
i ahve corvette heads with pushrod guide plates, so i don't need self-aligning. Thanks guys.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
