Need help quick...is reinforcement bar same between base model and Z28??
Old Jun 9, 2003 | 09:48 PM
CamaroX84's Avatar
I'm taking my car to the bodyshop tomorrow to get my front end fixed. It needs a new reinforcement bar (the heavy beam that is bolted onto the two front frame supports). I have an 84 Sport Coupe Camaro. I have a reinforcement bar from an 84 Z28. It says "Z28" on the bar, so I'm wondering, are they different?? Or will it work?? Thanks in advance.
Old Jun 10, 2003 | 10:00 AM
camaro6spd's Avatar
r you talking about the "the wonder bar", the bar that bolts up to where the sway bar also bolts up, or the cross member.
Old Jun 10, 2003 | 10:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I storngly suspect that they are different. The front fascia is significantly different on the Z28 from the 3-hole SC fascia. I seriously doubt that it will work, but I don't know that for certain.
Old Jun 10, 2003 | 03:54 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
If you're talking about the impact bar that sits in front of the radiator support, it is the same according to my service manual.
Old Jun 10, 2003 | 08:31 PM
CamaroX84's Avatar
Okay, I'm pretty sure the actual reinforcement bar is the same. The only difference is the big rubber piece that sits in front of it. That is different for a Z28 bumper cover. That was the part on mine that said Z28. Thanks for the help.
Old Jun 11, 2003 | 12:49 AM
99Hawk120's Avatar
I would definitely believe that, it is supposed to somewhat conform to the shape of the bumper cover
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
Fronzizzle
Aug 9, 2015 01:15 PM
