Is It Safe to Clean My Engine?
Old Jun 11, 2003 | 11:01 PM
85z28cmro's Avatar
I have two questions.
1.) I'm trying to clean my car up and show it off. A friend of mine told me it was ok to use soap and water to clean up under the hood. He told me to spray it all down. Is it safe to do that? If not, what it the best way to clean under the hood.
2.) My car sound squeaky when i rev the engine. I was told to wipe Armor All on the belts to stop teh squeak. It that safe to do?
Any input would be appreciated.
85 Z28 305 w/ new carb, air intake mods, aftermarket sound system
Old Jun 11, 2003 | 11:09 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
who told you to armor all ur belts? find that person and hit them becuz they are an idiot. go and get new belts and it will get rid of that squeeky sound. and also if u get armor all on the pulleys it might cause them to slip and that wouldnt be good.
Old Jun 11, 2003 | 11:16 PM
89rocs's Avatar
Car: '89 IROC
Engine: 5.7lt 350 TPI
Transmission: Original :(
I agree with Timz2882
Get a sock of hot nickles and beat wholever told you to armor-all your belts.
Make sure your belts are not too tight or too loose. I think maybe half an inch or an inch of play in the belts is good, but too much or too less will cause it to squeak.
Old Jun 11, 2003 | 11:27 PM
85z28cmro's Avatar
What about washing my engine? Is it okay to spray it down with a hose?
Old Jun 11, 2003 | 11:29 PM
89rocs's Avatar
Car: '89 IROC
Just make sure the car is not hot, and spray it down but keep away from anything electrical so you don't short anything out.
other than that, have a field day with the hose. I do believe they make special cleaner for the engine to help get grease/oil cake off.
Old Jun 11, 2003 | 11:33 PM
85z28cmro's Avatar
Back to the squeaky belts, I have heard that they make some sort of spray to stop the squeaks. Does anyone know about this?
Old Jun 11, 2003 | 11:35 PM
89rocs's Avatar
Car: '89 IROC
Yeah, they do. It's like a stinky type spray to help the belts grip the pulleys better to help stop the squeaking.
Are the belts old? When's the last time you replaced them?
If they are fairly new, just check the tension on the belts, too loose, tighten them, too tight, loosen them... and if all else fails, use the spray for the show.
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Be careful.....but you have to get it wet to get it clean.
I'll usually spray the engine compartment with simple green and let it soak in for a couple of minutes. Then I'll scrub dirty areas with a paint brush.
After that I'll hose it off quickly....being careful not to soak any electronics or connectors if possible.
When I'm done, I'll immediately start it and let it run for awhile to make sure everything is dry.
Old Jun 11, 2003 | 11:39 PM
85z28cmro's Avatar
My belts are about three months old and they seem to be tight enough. I am more concerned about the embarassing sound they make. Where can I find that spray?
Old Jun 11, 2003 | 11:43 PM
89rocs's Avatar
Car: '89 IROC
Autozone, Advance auto parts.. pep boys (shudder) NAPA, any car place really.
Old Jun 12, 2003 | 11:02 AM
Vader's Avatar
It seems to work fine for me:
Old Jun 12, 2003 | 11:05 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
BE VERY CAREFUL!!!!
You will kill the hell out of the throttle position switch if you get it wet!!!! Number 1 killer of dead TPS's is washing them at a high pressure car wash. Cover it!!!
Old Jun 12, 2003 | 11:43 AM
MX265
Guest
Posts: n/a
It's called Belt Dressing. It's made by several companies such as Permatex and Valvoline. Here is Valvoline's site:
http://www.valvoline.com/pages/produ...asp?product=32
Old Jun 13, 2003 | 09:57 AM
DukeVonGTA's Avatar
Nice 85 Z dude, I have an 86 with exactly the same color and T-tops too. It was my first TPI car and I will share my first experience at the car wash with a pressure washer. I wouldn't do it again. I lost my MAF, and throttle position sensor and had to have the thing flat bed to the dealer to be fixed. Thank goodness I just had to pay for the tow and the sensors were under warranty. Be very careful with the H20 stuff.
Old Jun 13, 2003 | 11:11 AM
Vader's Avatar
Laundry detergent, garden hose with hot water, and a stiff brush. Never had a problem except for failed ignition HT wires (which were already bad).
Old Jun 13, 2003 | 12:18 PM
Metaldrgn's Avatar
Car: Yukon, Tahoe, Expedition, JGC
loosen the accessory that is making the belt squeal and take the belt partly off to check that the accessory isn't frozen or freezing up because of bad bearings. If it feels ok, tighten it up as much as you can and take it for a test drive.
Yea, there's also some good cleaning stuff that you can get from autozone too(can't remember what it's called but it's for cleaning metal like a degreaser) and wash it off. The reason you don't want to wash it off when the engine is too hot is that you could crack the block. Let it cool for like an hour or so before you wash it.
Infested
May 22, 2018 11:56 PM
Polo Z03
Sep 10, 2015 06:43 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
