Fuel pressure dropping to 0 at WOT, need some help
Old Jun 12, 2003 | 03:58 PM
CAMAROsc350's Avatar
I am running a mallory regulator with a return line to my carb, and am still using the tbi pump. At idle i am between 6 and 7psi, if i get on it more than half throttle it drops to 4psi. The real problem is when i floor it my pressure immediately goes to 0. I have a nordskog digital fp gauge to monitor my fp. What could be causing this, what should i check? All opinions and suggestions are apreciated.
Old Jun 12, 2003 | 08:16 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i'd say your filter is plugged or the pump is going. i have a carb so i'm not familar with your pump but my holley blue maintains 7 psi at wot
Old Jun 12, 2003 | 09:47 PM
Vader's Avatar
Flow test your pump to an open container. Measure the flow delivered from the pump in 15 seconds, then multiply by 240 to get the GPH delivery. If you're not getting 30 GPH, you have a pump, filter, line, or pickup issue.
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
