Misfire above 5500rpm
Old Sep 22, 2000 | 11:58 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have a misfire that I've narrowed down to either valve springs or ignition. I'm leaning more toward the distributor because it doesn't happen every time and the misfire pattern isn't the same. It typically occurs between 5500-6000 rpm. I run a stock HEI with computer controlled advance, .040 gap spark plugs, and 8mm wires. What distributor should I buy?
1986 CAMARO Z28 -> 150,000 original miles, 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, reinforced LCA's w/bushings, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Adjustable panhard rod, LCA lowering brackets, homemade ram air, B&M shifter.
Old Sep 23, 2000 | 12:08 AM
'92_B4C's Avatar
Don't buy a new dist., buy a new chip. Your chip limits your RPM range.
Old Sep 23, 2000 | 12:10 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
What about advancement? How do I know how much timing it is giving me? How is it going to be optimal?
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
