What happens if an injector is going bad and u are running nos?
Old Sep 21, 2000 | 10:44 AM
Brandog87GTA's Avatar
I have a rough idle, and I've changed my plugs, cap and wires. The miss is still there and I am ordering a 100HP shot of nitrous tomorrow.It runs fine at anything other than idle. If I put the shot on and one of my injectors is ****ing up, will it cause detonation? How can I test my injectors?
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with Bosch platinum plugs, Accel distributor cap and rotary buttons.Gutted cat. Hope to port runners and plenum in about 2 weeks.
Old Sep 21, 2000 | 09:50 PM
Andy89RS's Avatar
I'm no expert on NOS, but I do know that having an insufficient fuel supply is a great way to break expensive parts on NOS. If one of your injectors is bad it will run that cylinder lean, which isn't good under normal circumstances. When using nitrous, it becomes vital that you have enough fuel, otherwise you can run extremely lean and burn valves, pistons, and generally do lots of expensive stuff to the inside of your engine...
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Sep 21, 2000 | 11:22 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
not a big deal. if an injector quits working with the nitrous on it'll just vent it's self through the piston.
Old Sep 22, 2000 | 08:32 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
zippy, you're a moron. If an injector fails, as in stops firing, he will destroy that piston/exhaust valve very quickly with juice. If your engine is in anything less than perfect tune, do not even think about spraying it.
...ed
Old Sep 22, 2000 | 08:42 PM
Andy89RS's Avatar
In zippy's defense I think that was written with a heavy dose of sarcasm... "it'll just vent it's self through the piston" (by putting a hole in it)
Old Sep 22, 2000 | 08:46 PM
crazeinc's Avatar
don't even think about it until you get it fixed, because they're right, it's suicide for your motor
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(383 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Sep 22, 2000 | 09:48 PM
Box of Rocks's Avatar
Hey ! Was Zippy one of the seven dwarfs ?
You know:
Dopey
Sneezy,
Cokey
Zippy
etc.....
Nah!
But you could be right about the piston ventilating itself in the presence of pure nitrous and no gas.
Of course, I would expect from the symptoms described, that even if the problem IS an injector that is lazy at idle, the builder will not have a problem for long.
If said injector problem is caused by varnish/crud buildup, it should be blasted clean the first time the fuel enrichment circuit kicks in on the modified system. And, I would expect the builder to "cold test" both the fuel and nitrous loops.
Oh, by the way, if you purge your nitrous into the cylinders, make sure you disconnect the coil and spin the motor over a few times. This will prevent your SBC from turning into a very expensive hand grenade when you fire it up with a load of spray sitting in the cylinders.
Also, I'd recommend a dual relay setup that ONLY arms and enables the spray when two conditions are met:
1)The microswitch which you've positioned at the end of your throttle linkage is activated, and.....
2) Le motoeer is spinning 2500+ RPM.
And uh, lastly, like the other guys said, play it safe and diagnose/repair the miss at idle BEFORE playing with the HE. (That's high-explosive for all you whippersnappers).
Good luck.
BOR
Old Sep 23, 2000 | 12:34 AM
zippy's Avatar
Engine: 5.3L
i'm impressed. i'm a moron for pointing out that the piston would vent itself. kinda takes a moron to not realize pistons don't vent themselve without a hole in it. and i'm the 6'4 dwarf playing with snow white. yes i have a good sense of humor.
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
squiggy2
Aug 9, 2015 09:30 PM
