Another rough idle/acceleration post
Old Jun 16, 2003 | 12:44 AM
T/A gets T&A's Avatar
I just searched for about 2 hours and didn't see anything like my situation.
I just installed a new cap, coil, rotor, wires, plugs, and module with all Accel stuff. Now the car will start right away with no problems, but the idle is 'slightly' rough. When accelerating, there is a noticeable loss of power almost like one cylinder isn't firing. I know that injectors are possible, but since it happened IMMEDIATELY after changing the ignition stuff, what would be the most likely cause? I hear people talking about their aftermarket modules pretty bad. Does this sound like it?
Old Jun 16, 2003 | 09:44 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
are you positive you have the firing order correct? if you have 2 backwards it will cause the kind of problems your describing
Old Jun 16, 2003 | 10:26 AM
Vader's Avatar
It's very easy to get the wires installed incorrectly. I've done the "5-7 swap" more than once...
Old Jun 16, 2003 | 01:43 PM
Morley's Avatar
Also, make sure the plug wires are clipped securely on the cap terminals and on the plugs.
Old Jun 16, 2003 | 02:11 PM
D'OH!
five and seven WERE switched! Good thing I can follow a simple Chilton's diagram huh?
Thanx for the help guys!
Chuck84TA
Jul 15, 2016 09:05 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
db057
Sep 4, 2015 07:57 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
