quick head gasket question
Old Jun 16, 2003 | 02:15 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Who makes the thinnest head gasket (compressed) out there, I'm looking to pick up a littl compression in the 305.
Old Jun 16, 2003 | 02:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Fel-Pro
375-1094 Embossed Shim Bore: 4.100''
Compressed Thickness: .015'' $19.99
Mr Gasket
720-1130 SB-Chevy Compressed nominal thikness .018''-.020'' $16.99
Make sure the deck surface of the block and the heads are FLAT!!!
Old Jun 16, 2003 | 03:09 PM
Car: 83 Z28
That numbers not working for a 305, would you happen to have another?
Old Jun 17, 2003 | 05:25 AM
ede's Avatar
ede
using a thiner head gasket isn't the way to increase compression and the change would be very slight and could lead to more problems then the gain would be worth.
Old Jun 17, 2003 | 06:06 AM
Car: 83 Z28
I'm only looking to bump it alittle.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
