Stumble in 90 TPI
Old Sep 25, 2000 | 06:20 PM
Pro-T's Avatar
Stumble in 90 TPI
Problems with my engine will start to stumble then cut out when throttle is increased. Have hooked up a pressure gauge to it and fuel is Ok. I have also traded out the the modual in the distributor with no inprovement. The map tested out OK but the
tps had a small flat spot at3/4 throttle.
Old Sep 25, 2000 | 06:27 PM
Vader's Avatar
Pro,
The dead spot in teh TPS is certainly no help. Make sure the TPS voltage at idle is correct, even if it non-adjustable there is a specified range. Assure that the minimum air position is set to 500-550 RPM. I presume you have TPI, so you might benefit from relocating the MAT sensor to a cooler location.
You might also want to check the EGR and PCV operation.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
mdtoren
Aug 23, 2015 12:52 PM
Winchester1094
Aug 18, 2015 10:23 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
