i need recomendations on gasket&on oil pumps more within
Old Sep 26, 2000 | 07:24 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i just got a GTA with a 5.7tpi the previous owner did some work on the motor new main bearings, new rodbearings, cam,cam bearings ,timing chain,he also installed an oil pump about 3 mnths ago that puts out 55lbs of o.p. at about 2k rpm when warm. 30 at idle. but it already has an oil pan gasget leak. i am gonna pull the pan to fix what gaskets would seal it best with all that oil press?would u use a chemical sealer? i thought of replacing the oil pump with a stock one. what do u suggest? whats the diff between high pressure and high volume oil pumps whats better? i dont want it to start leaking again like b4. thanks ed
Old Sep 26, 2000 | 07:37 PM
Guest
Guest
Posts: n/a
The oil pan leaking doesnt have anything to do with the oil pressure, theres no pressure present on the oil pan gasket besides whatever blowby you might have.
I'd just stick a new gasket on there with no sealer (they are rubber) and leave the rest alone.
High pressure is just that, used just to make sure there is plenty of pressure to get oil to all the moving parts under higher loads. High volume pumps more oil through the system and should really only be used if you have a bigger oil pan otherwise you could run out of oil at sustained high RPM's.
Old Sep 26, 2000 | 08:43 PM
ede's Avatar
ede
can't say max is wrong, or that his way won't work. i prefer to use permatex hitack on the block to hold the gasket in place and a very thin layer of permatex ultracopper silicone on the pan. make sure you don't have "dimpples" where the bolts try to pull thru the oil pan and make sure you don't over tighten the oil pan bolts.
-=ICON MOTORSPORTS=-
Old Sep 26, 2000 | 09:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
On oil pan gaskets I put a little sealer in the corners of the front and rear seals, and nothing on the pan rails.
If I'm working upside down and I need to stick the pan to the motor, I will use 3M wheatherstrip adhesive (the yellow stuff) on the block to hold the gasket up.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Engineboy's Avatar
Car: yep
Engine: uhuh
...ooops.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited September 26, 2000).]
Old Sep 26, 2000 | 09:19 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I hate when I do something on the comp. and it just sits there......doing nothing....so I click on it again....still nothing.....so I click on it again.....Then it decides to catch up with itself.....DOH!! 2 posts to edit.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
