why does this happen
Old Jun 19, 2003 | 07:26 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
on my alternator the bolt for the wire that goes from to the back of the alt to the battery is loose and turns when i try to take the bolt off. So there was alittle plastic piece i took out between the alt and bolt. Now when the bolt with the wire touches the back of the alt it makes a spark..
why does it do this?
Old Jun 19, 2003 | 07:32 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
alternator is grounded to the engine. that plastic piece is to keep that from happening. if you are having problems with the bolt turning when you are trying to take off the nut, take another small wrench or plyers and hold the inner nut, while you pull off the outer.
25thanniversZ's Avatar
the plastic was an insolator, kept the bolt from grounding out on the alt
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
