will a 454 motor go in a camaro
Old Sep 25, 2000 | 09:16 PM
82camarov6's Avatar
will a 454 or 455 motor go in a camaro and
any body have photos
Old Sep 25, 2000 | 09:21 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
yes it will fit.
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I know it will fit, I've seen one at one of our cruise inn's we have here in Virginia Beach. It was an 85 Camaro with a 454 with a big blower on top. He had to do a little cutting and move the radiator forward a little bit. He also had a removable hood with a big hole cut into for the top of the engine to stick out of.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
Old Sep 25, 2000 | 10:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
A 454 will go.
The 455 is a Buick/Olds/Pontiac motor that won't bolt up to the trans.
Hooker made a kit to do the 454 BBC swap....I think I have a P.A.W catalog at the shop that shows the kit.
I'll look tomorrow.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited September 25, 2000).]
Old Sep 25, 2000 | 10:23 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
is the 427 a bigger motor? i heard that there was all kinda of frame mods and firewall bangin in to do...
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: GOT A 350 IN THE WORKS BABY! gonna throw my TES edlebrock headers on it, and hopefully get some more gear and the cowl hood on
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Sep 25, 2000 | 11:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
427 and 454 are externally the same, much as a 305 and 350 are the same. Internally, they are the same bore; the 427 has a shorter stroke (3.75") which is the same as a 396 or 402. In fact you can create your own 427 by putting a short-stroke crank in a 454 block.
One of the beauties of Chevrolet motors is that they have the same motor mount placement and the same bell housing bolt pattern. As a result a big block will bolt right into our cars. Exhaust is a bit of a challenge, as is getting it to fit under the hood; and they have trouble with A/C evaporator housings, power brake boosters, steering columns, and wiper motors. There are several people on this board who have them in their cars, and are willing to soread the knowledge around.
Old Sep 26, 2000 | 02:08 PM
84IROC's Avatar
I once dropped a chevy 454/TH400 into a 1981 olds Cutlass Supreme with very little trouble. The biggest probs were I had to use an electric fan and I had to fabricate a tranny mount, other than that is was pretty straight forward. It actually had holes in the frame for the correct engine mounts!
front springs were a bit weak though.....
sorry about getting off the subject just thought it might be an interesting tidbit......
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 26, 2000 | 02:45 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
All the info you need is on my page. Let me know if you have any questions.
Stephen - Sleeping today? Or are you already working on that new 454?
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
http://www.geocities.com/MotorCity/Track/5604/
Old Sep 26, 2000 | 10:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't get into this forum as much
I'm currently in the process of dropping a 454 big block into my race car this winter. It's a pretty straight forward swap. Things get a little tricky in a street car. Clearances are tighter. It's not impossible to do, just a little difficult. Miles (88 427 camaro) has an excellent page on how to do the swap.
It's also possible to drop in any of the 455 engines but you'll have to fabricate everything yourself. Nobody makes any sort of conversion parts to do those swaps. One thing you would need to do is change the tranny to one with a BOP bellhousing since all three of those engines are different than the chev pattern. Stock exhaust manifolds "may" fit but custon headers would have to be made. You can drop any engine into any vehicle with a little engineering and planning. Some just fit better than others.
If you can get one to fit, an Olds 455 would be a real torque monster. Probably destroy the little diff under the camaro in stock trim. You could also go really exotic and drop in a 500 Cadillac engine. It could fit but much more planning would be needed.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
