Valve Lash
Old Jun 22, 2003 | 06:07 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Valve Lash
WE are in the middle of a valve seal job.. We tried counting the number turns required to take rocker off.. but we are only close.. 6-6.5 turns..
The car has crane 1.6:1 roller rockers.. *** knows if there is a cam in it.. i assume stock.. is there a way to know? without looking at it.. ..
Also .. how do you set the valve lash?
Old Jun 22, 2003 | 06:32 AM
ede's Avatar
ede
i measure the distance from the top of the nut to the top of the stud with a dial caliper, makes it real easy to put back together. a bolt and jam nut arrangement will work in a bind. look in your manual or search here for how to on valve lash.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
