Oxygen sensor readings?
Old Jun 22, 2003 | 10:29 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I cant get my O2 over 750 mV is this a sign for a bad sensor?
I've tried everything and it still doesent get over 750 mV any time...................(I ve tried open my injectors static @ 3500 rpm and still under 750 mV)
Could it be I need a heated one? that my exhaust cools it down? I know the output depends on the temp. but not how much and how.............
The sensor only has 200 km on it and it "looks" good.
It varies between 0-650 mV at idle and at 2000 rpm (havent tried higher) and then I unplugg the vacuum to AFPR and still I cant get it over 750 mV?...........It sees 0mV alot........
Old Jun 22, 2003 | 10:56 AM
Vader's Avatar
Have you tried to remove the sensor and test the mV output with the tip in the presence of a propane flame? A propane flame is generally devoid of all oxygen, and this test should yield the highest output voltage the sensor is capable of producing.
Old Jun 22, 2003 | 11:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Hmm........no............
I'll have to check at work to se if I can do it there.....Just tried a PROM that was made to run pig rich and still not over 750 mV but tha car run like crap............
/N.
Old Jun 27, 2003 | 02:08 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Today I tried a heated one..same result..... nothing above 700mV.........
I'll check the wiring tomorrow otherwise I dont have any clue............
any ideas?
/N.
eightsixseven
Dec 16, 2024 01:50 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
beast94
Aug 20, 2015 06:44 AM
mdtoren
Aug 16, 2015 05:45 PM
