Timing Spec's for 92 RS 305 TBI
Old Jun 22, 2003 | 12:12 PM
Camaroman92rs's Avatar
I've looked everywhere trying to find exactly what degree my timing should be set at.I no longer have the VEHI sticker that would normally have this information.I have a 1992 Camaro RS with a 305 TBI/with air.700R4 Transmission.Thanks.
Old Jun 22, 2003 | 12:51 PM
iroc22's Avatar
Stock setting is 0*
Obviously you can advance the timing more than that however.
Old Jun 22, 2003 | 12:58 PM
StangKiller's Avatar
Stock setting is 0 deg. and you have to disconnect the computer advance to the distributor before you set it by unhooking the connector on the tan wire with a black stripe that pokes out of the wireing harness on the passenger side of the firewall. Most guys will advance it by 2-6 deg. to get more power out of it, just watch out for pinging if you do. I had mine advanced 4 deg.
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
