wierd white smoke, any ideas?
Old Jun 23, 2003 | 09:13 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
i just put a 406 together and put about 500 miles on it, had a lifter colapse (bad summit lifters) changed them and put the intake back on with new gaskets and now I have two problems. the coolant bubbles when i filled the radiator with the motor running and when i reved it, it smoked right after i let off but not when i was giving it gas. Could this be and intake gasket? misadjusted valve? or a head gasket? by the way, it didnt do it before i put the new lifters in it and it still has plenty of power and runs good thanks
Old Jun 23, 2003 | 10:54 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
since you were just messin with the intake i would venture to say a leaky intake gasket....
Old Jun 23, 2003 | 11:19 PM
camaro03's Avatar
Car: 1982 camaro
i am just checking to make sure thats possible, the water jacklets on the intake are pretty far awar from the inlets for the fuel, plu theres no water in the oil, thanks
Old Jun 24, 2003 | 07:06 AM
89RsPower!'s Avatar
yup very very possible
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Cripley
Aug 17, 2015 03:35 PM
stalkier
Aug 13, 2015 12:59 PM
