Tranny jults hard...
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
I have an automatic transmission, and when I put it into reverse, or drive, it causes the car to jolt really hard... Jolts harder when put into drive than in reverse though. Once in drive it shifts through the gears perfectly. Any idea's why it does this or how to fix it? All input is appreciated!
Car: 1985 Berlinetta
Engine: 305 4BBL
Check the idle on the car. If it idles too high it could cause the jolt. Also check U-Joints, leave the car in park and turn back and forth looking for slop. Finally, have someone hold the brake on and put the car in drive and reverse. Pay attention to how much the engine moves, could be a sign of bad motor or tranny mounts.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
