power bulge experts come in...
Old Sep 29, 2000 | 08:58 AM
Locry's Avatar
do all power bulge hooded 'birds have a honeycomb grille in the opening? i remember reading somewhere that some came with blocked off openings... what came with what?
when i got my t/a it came with a honeycomb grill, i was wondering what the bulge really was for...
Old Sep 29, 2000 | 09:57 AM
David Trimble's Avatar
I'm assuming you're talking '84 T/A - I've got one with a factory power bulge and it does come with the honeycomb 'grille'. I'm positive of this as I'm the only owner and I know it's never been touched.
Hope this helps!
Original owner - '84 T/A w/stock 305HO 5-speed
Old Sep 29, 2000 | 11:21 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Only the carburated ones had the honeycomg in the power bulge hood . the tbi ones had a solid tin sort of thing in its place non funtional. I have a stock air cleaner and cover for sale for one if anyone is looking
Thanks Kevin
Old Sep 29, 2000 | 11:48 AM
Locry's Avatar
oh sorry bout that, its an 83 t/a... the original induction might have been changed when it was still a 305, i recently swapped it for a 350... the reason i ask is because i heard that there were functional induction type power bulge hoods... just wonderin if my car originaly came with that...
Old Sep 29, 2000 | 12:11 PM
theformula's Avatar
I think they aren't functional because of where the water will go! A guy here with a TPI completely ruined his engine by taking off the block on his power bulge. The first thing that went was his distributor. Some guys say it's good to hae it open to cool the engine , which is also B.S. I tried it for 3 days and my engine did not run any cooler at all. anyway, sorry about getting off topic, it just brought back a memory.
Old Sep 29, 2000 | 12:42 PM
gman10101's Avatar
Car: 84 T/A HO*
Transmission: Tremec TKO 5-speed
Actually, the "bulge" is functional on some models of T/A. I've got an '84 that originally had a carbed 5.0, High Output motor. The bulge is functional in that when you go to WOT, the computer sends a signal to a hood mounted solenoid, and opens a door in the bulge. This feeds outside air into the carb via the air-cleaner cover, which has a gasketed opening to allow the additional air in.
Old Sep 29, 2000 | 02:30 PM
Right, what Gman said. That's the exact setup I have and I believe it only came with the H.O. option.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
