Engine wants to stall
I have 87 IROC with a 350 tpi. I recently have been having a problem with it wanting to stall when i first start it. It also does not seem to run as smooth as before. Does anybody have any advice for me?!!!
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Join the club. I'd start with the fuel filter, the fuel pressure, and then test the EGR system. The EGR system normally won;t cause start-up problems, but it;s as good a place to start as any. Make sure you're getting enough air through the intake. Also, have you done any work on the plenum, TB, or the runners lately?
