where did my oil pressure go??!!
Old Jun 25, 2003 | 10:07 PM
breathment's Avatar
ok car has been sitting about two months with the plenum, runners, and injectors off. i finalyl got everything put back together today. it started and ran rough (like i expected) and then finally stayed running.. it was running like crap (RPMS jumping from 500 to 1500) so i reved it up a little and i heard this whirling type noise coming from the engine. it was pretty loud so i went and checked the oil pressure (just our of curiosty) and it was at about 30 PSI, usualy is past 60 when its jsut started.. i shut it off. waited 5 min, checked the oil and it seemed to be like 3 inches higher than it should be.. i cant' tell if it was just cause oil was on the walls of the dipstick tube or what but it seemed really odd.. well to make a long story short. half an hour later im driving around, 15 psi idle. 30 psi on the highway at higher RPMS. im hoping its just an oil pressure sendign unit. but could something of happend internally during that two months of sitting that could cause this?
Old Jun 26, 2003 | 02:11 AM
25THRSS's Avatar
That is normal. Nothing to worry about. What is it when you're florring it?
Old Jun 26, 2003 | 04:44 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If there is something wrong, don't overlook simple things like the sending unit.
Old Jun 26, 2003 | 05:21 AM
flyin89's Avatar
It sounds like you've got gas in your oil! Check it over running it this way will ruin your engine.
Old Jun 26, 2003 | 03:40 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
those oil pressure readings sound perfectly normal.. but if in fact your oil level is high smell it to see if it smells like gas.. make sure it doesnt look milky or you might have some coolant in there.. as far as the jumpy idle and the whistling i'd say you have a pretty decent vaccum leak.. listen for it.. if ya cant find it search for it with a can of starting fluid or carb cleaner or somethin..
Old Jun 26, 2003 | 11:50 PM
breathment's Avatar
ok its not normal if its never done this before. but however today i did drive to work and the pressure seemed much higher. i think its the sending unit
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
