Problem with my 92 camaro
Old Jun 26, 2003 | 12:41 AM
-forsaken-'s Avatar
My car is acting really funny, I will go to accelerate and it will start to shift up and down a gear repeatedly. After a little bit it stops. It was doing this a while ago until the speedometer sensors went out and now I thought I had it fixed but it's started again. Any ideas?
Old Jun 26, 2003 | 04:57 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Not enough information. It shifts gears repeatedly?!
Old Jun 26, 2003 | 08:42 AM
-forsaken-'s Avatar
Well it's weird and I don't really know how to explain it. If I'm just driving it usually will happen around a certain rpm (generally the ones the car travels at the most) But it will just start revving up and then suddenly drop down to lugging (when it's the most extreme) and just keep bouncing between the two of them. There's no middle just bouncing between revved really high and lugging. When I am stopped and beginning to accelerate it makes the car lurch a little because of it (like I said it's not really bad YET but it started out small the first time also). I've taken it to a few mechanics but no one around here knows ANYTHING about cars I guess.
umm... it's a 92 six cylinder automatic...
thanks to anyone who tries to help
-jasmine-
Old Jun 26, 2003 | 09:31 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
-jasmine-
Well that explains it! Have you done the basics and checked to see if you have consistent fuel pressure, good spark, any error codes show up on the diagnostic (you said you took it to a shop)?
Old Jun 26, 2003 | 03:33 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
sorta sounds like a tcc lockup problem.. try posting in the trans board you might get some more replys..
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
