Oil pump pick up....?????????
Old Sep 30, 2000 | 12:15 PM
z28cam100's Avatar
Car: 89 Trans Am GTA
How do i get my oil pick up onto the new oil pump?? Is there some kind of special tool to use?
86 Camaro
305, T-tops, flowmaster exhaust, B&M shift kit
"Real cars are built, not bought"-some smart guy
http://hometown.aol.com/z28cam100/index.html
Old Sep 30, 2000 | 01:19 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I used a flat blade screw driver just tapped around it as it went in. They do have a tool for it but i dont know were to get one. If you have some pipe stock you could probably make your own.
Dont forget to set the right height from the bottum of the pan. And its a good idea to braze the pickup to the pump so it doesnt fall off.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Sep 30, 2000 | 02:14 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Or use a rubber mallet, that's what I use. Jeg's, Summit or PAW have the tool MikeH is refering to (Oil Pump Screen Installation Tool). They sell for $19.95 for the 5/8" tube or $21.95 for the 3/4" tube
Remove the pressure springs first to avoid damaging it.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Sep 30, 2000 | 02:19 PM
Vader's Avatar
Z28,
Just in case you didn't see it in Mike's post, definitely BRAZE the pickup tube to the pump once the depth and angle are set.
You'll sleep better if you do - trust me.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 30, 2000 | 03:54 PM
z28cam100's Avatar
Braze as in wled it?????????
Old Sep 30, 2000 | 11:52 PM
ede's Avatar
ede
brazing isn't welding. if you do anything weld it, less heat input. i prefer to weld a brace to the pick up and bolt it to the pump. no chance for warpage that way.
-=ICON MOTORSPORTS=-
Old Oct 1, 2000 | 01:40 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I use a wire feed and just tack it.
You don't need to weld all the way around the tube.
I usually set the pick up height, then take the pick up and the bottom of the oil pump housing off.
I weld it with it off to keep slag out of the oil pump. This also gives you a perfect time to fill the oil pump rotors with assembly lube.
Don't forget to put locktite on the four bolts that hold it together.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 01, 2000).]
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
