Non-thirdgen, is my truck flashing a code??
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
on my 91 silverado 350 TBI my emergency brake
light started flashing, it flashes in regulare pulses. 8 quick flashes with one long one and then another 8 and so on. Does this means its flashing a code? if so do you have any idea of what its complaining about?
1982 Camaro Z28
"Vortec 305"
-KIA
Project "VortecZ"
rebuilt 355, GM 9.5:1 pistons, GM Vortec crank
GM L31 Vortec heads, Competition xtreme energy cam, edelbrock Perormer rpm vortec, edelbrock 750 carb, dynomax shorty headers, accel ignition, bosch platniums,edelbrock ProFlo aircleaner, Flowmaster 3 chamber exhaust, Richmond 3.73 rear, rebuilt dif, rebuilt 700r4, modified shifter, homade ramair, factory fiberglass hood,
and some other stuff
"if its broke, dont fix it. just replace with it's high performance equivalent." -Me
1982 Camaro Z28
"Vortec 305"
-KIA
Project "VortecZ"
Jer,
You may have a brake pressure differential switch sensing a leak in either half of the brake hydraulic system, or it may be an antilock brake warning. If you still have your owner's manual, it should detail the function of the light. Typically, if the park brake is stuck on, the light will remain on instead of flashing.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
