I converted my smog pump to a crankcase vacuum pump..it works but...
Old Oct 1, 2000 | 03:49 PM
Jester's Avatar
BUT it's noisy as hell. It pulls alot of air it seems. It'a fine with the line uncapped at idle...but when you plug the end of the hose or rev it, it sounds like a damn 2 stroke chainsaw. It's only pulling through one 3/8" fitting.....so even with no hose on it it starts making the noise above 2500 rpm give or take. If I could get it to stop making noise when it sees vacuum..it'd be great.
I did it by blocking off the intake port (.5"x2" slot) behind the plactic fan, and drilling a hole and JB welding in a 3/8" brass elbow into the top of the pumps intake port. Then I ran a hose from that up to the PCV on one valve cover, while plugging the other side.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Old Oct 1, 2000 | 08:10 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
I made similar modifications to mine for my new engine. It will be next weekend before I get to install the motor and try the "vacuum" pump. How much vacuum does yours pull?
Old Oct 1, 2000 | 08:21 PM
crazeinc's Avatar
That's an awesome idea, especially since vaccumm pumps are a ridiculous amount of money...way to go! That's an idea for the new motor...
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website (New design in progress...very cool look)
(383/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 1, 2000 | 08:29 PM
Jester's Avatar
I don't have a vacuum gauge to stick on it yet..it seems significant though.
Also..don't forget so far it is too noisy to actually use. I have a couple ideas to make it work...I'm gonna put in a second port for the other valve cover to halve the built in intake restriction, and maybe put some sort of muffler on the exaust end of it. I'll keep ya posted.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
